Silicone Grease and Silicone Oil
Larbo
California
Years ago I found the joys of silicone grease for use with threaded and rubber-interfaced connections (never leave home without it... so to speak!).
I have a water faucet with a spout that rotates on the kitchen sink for an undercounter-type filter. That rotation has gotten a stiff over time and I thought about what kind of lubricant I could drip into that joint to safely loosen/lube it up. Anything petroleum based will ruin the o-ring and silicone grease is too thick to physically get to the problem area. Hence, my brain thought of silicone oil.
So, for this need, are there any recommended "oily" lubricants? Is silicone oil (not spray) safe to use here and is there a plumbing precedence for its general use in the field? Just wonderin'. Thanks
