Silicone caulk vs. latex caulk
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by midge, Jul 12, 2008.
  1. midge
    midge New Member
    Jul 6, 2008
    We are in the process of installing a sink vanity and the manufacturer's directions say to use a latex caulk. Is it okay to use silicone instead?
    Thanks.
  2. hj
    caulk
    Yes, it may just be messier.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    The mess... There will be one, can be cleaned up with Denatured Alcohol and a rag...
  5. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    use the latex....
    if you use DAP or latex caulk you will be fine.....
    if you use the silicone caulk, then you are pernamently
    installing that sink, because the silicone will never allow
    you take that sink out ever again is is in for good and will
    have to be broken to get it back out.......
    you only have to make this mistake once.....
  6. midge
    midge New Member
    Jul 6, 2008
    Latex it is then. Thanks!
  7. Ian Gills
    Jul 24, 2007
    USA
    Let's just put something out there.
    Latex definitely to sit a sink on a vanity or to seal the gap against the wall but I would only use silicon to seat the drain against the sink.
    I used latex on my utility sink drain and it developed a leak. I redid it with silicone and now the leak has gone.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    Plumbers Putty works well for setting drains.
    I do not advocate gluing things in with Silicone RTV.
Similar Threads: Silicone caulk
Plumbing Forum, Professional & DIY Advice Caulk: Silicone,Polyseamseal, Hercules or Other? Jul 23, 2011
Plumbing Forum, Professional & DIY Advice How to be neat with Silicone Caulk? Nov 1, 2005
Plumbing Forum, Professional & DIY Advice Acrylic Tubs - Silicone vs Plumbers Putty Jan 6, 2017
Plumbing Forum, Professional & DIY Advice PVC cement - compatible w/ silicone sealant? Sep 6, 2016
Plumbing Forum, Professional & DIY Advice Replacing Old Kitchen Faucet - Putty or Silicone Jun 14, 2016
