Silicon in Wire Nuts
Discussion in 'Electrical Forum discussion & Blog' started by seaneys, Aug 19, 2007.
  1. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Does anyone squirt silicon in wire nuts in damp locations (basements, etc)? I've heard of it, but have never actually done it. Is it worth it for a location that is never intended to get wet?
    Thanks,
    Steve
  2. snafflekid
    snafflekid Electrical Engineer
    Apr 23, 2007
    Electrical Engineer
    Wait, do you mean silicone caulk? I don't know of a specific rule against it, but I would say it is a very bad idea. Wire nuts are flame retardant (don't think silicone is) and you are going to have a hard time actually making a watertight seal. "Damp" is not the same thing as "exposed to wetness" in which case you need to use moistureproof boxes.
  4. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Silicon can not be used on conductors period!!!!
  6. HandyAndy
    HandyAndy General Contractor, Farmer
    Apr 17, 2007
    Haxtun, CO
  7. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    SILICON is a nonmetallic element that is used in manufacturing electrical components. It is also a common element is compounds such as glasss and sand.
    SILICONE is a class of organic compounds that include the element SILICON.
  8. hj
    wire nuts
    Usually those blue connectors are labled for low voltage only.
  9. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    110.11 Deteriorating Agents.
    Unless identified for use in the operating environment, no conductors or equipment shall be located in damp or wet locations; where exposed to gases, fumes, vapors, liquids, or other agents that have a deteriorating effect on the conductors or equipment; or where exposed to excessive temperatures.
    FPN No. 1: See 300.6 for protection against corrosion.
    FPN No. 2: Some cleaning and lubricating compounds can cause severe deterioration of many plastic materials used for insulating and structural applications in equipment.
    Some of the off the shelf silicon agents will damage the insulation of some types of conductors.
    If silicon is going to be used on electrical conductors or equipment it needs to be listed and labeled for the prupose.
  10. HandyAndy
    Apr 17, 2007
    Haxtun, CO
    Thank you for the information and I apologize for my misspelling of Silicone
  11. Bob NH
    Oct 20, 2005
    New Hampshire
    I wasn't criticizing the spelling.
    Lot's of people confuse silicon and silicone.
    It's like concrete and cement. Many people look at concrete and call it cement.
    Cement + aggregate + water --> concrete.
    Silicon + various other elements --> Silicones
  12. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Look at my posts
    I left the E off on purpose
  13. snafflekid
    Apr 23, 2007
    Electrical Engineer
    Okay, I bet you are referring to silicone grease. This stuff is okay to use and is often found in automobile wire harness connectors, where moisture is a problem. I was thinking bathtub caulk heheh
  14. Rancher
    Rancher Guest
    We used Silicone in manufacturing back in the 70's to keep CRT monitors in the computer industry from arcing from the high voltage section to the outside case. It was GE's RTV stuff. However that said I wouldn't add any thing to a wire nut, it either should be in a dry enough location not to need anything else or it should have the proper weather proof enclosure to protect the connection.
    Rancher
  15. seaneys
    seaneys New Member
    May 8, 2007
    Chicago Suburbs
    Thanks a lot for the clarification. I thought something seemed 'strange' when I noticed this in more than one trusted reference. I held off since it seemed overkill. Our basement is humid, but not THAT humid that I would call it damp.
    Steve
  16. Livin4Real
    Livin4Real New Member
    Sep 7, 2007
    Flight Operations and DIY'er
    Indianapolis, IN
    May have been mentioned but if your worried about it you can use dielectric grease on the nuts (wire of course, not your own, unless your into that :p )
    Also referred to as marine grease (what they use on lights on boat trailers, etc.) And if your basement is that damp you should have a dehumidifier.
Similar Threads: Silicon Wire
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog What Monkey Wired this outlet?? Jan 10, 2017
Electrical Forum discussion & Blog Electrical wire accidently charred. Dec 31, 2016
Electrical Forum discussion & Blog Need C wire for new Honeywell RTH8580WF Dec 13, 2016
Electrical Forum discussion & Blog Question on 3-wire Kitchen Range > 4 wire Nov 24, 2016
