shutoff requirements
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by peltaz, Mar 21, 2009.
  1. peltaz
    peltaz New Member
    Nov 18, 2008
    If using a home run system with pex are individual shutoffs still required at each fixture if the manifold is easily accessable? What if a flow through manifold is used to connect say a sink and toilet on the same supply line?
    Thanks.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Shutoffs are still required at the fixture. Manifold systems must be properly engineered for flow also. There are some very specific codes and requirements to installing home run systems.
  4. hj
    manifold
    IF the manifold has individual valves for each connection AND it is properly labled then the fixture stops are not required. BUT this also means that the manifold is ALWAYS accessible, usually in an cabinet. Having an accessible manifold without valves does not provide any means of isolating a fixture so it would still require the stops at the fixture.
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    HJ, I can't find that in the code. Not saying it ain't, just can't find the section. Are we looking at IPC or UPC?
  6. hj
    stops
    The valve at the manifold satisfies the requirement for individual shutoffs. ALL of the installations in this area with manifold valves have the tubing run directly out of the wall and to the faucets.
Similar Threads: shutoff requirements
Plumbing Forum, Professional & DIY Advice Location requirements for shower/bath shutoffs Sep 1, 2013
Plumbing Forum, Professional & DIY Advice Shutoff Valve Won't Open Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Finding Replacement Shutoff Valve Handle Nov 13, 2016
Plumbing Forum, Professional & DIY Advice Replacing valve at waterline shutoff to house Oct 26, 2016
Plumbing Forum, Professional & DIY Advice Refrigerator shutoff valve failure Oct 20, 2016
