shut off valve leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by jdon88, Jul 11, 2010.
  1. jdon88
    jdon88 New Member
    Jul 7, 2010
    Pottstown PA
    This seems to happen to me all the time. I just bought an older home and have some work to do before I move in. i thought it would be a good idea to turn off the main water supply since I won't be back at the house for a week or so. When i turn the valve back on it now has a slow leak from the stem. Seems like any of the shut off valves that haven't been operated for years will start leaking if I turn them.
  2. jimbo
    jimbo Plumber
    Not unusual. It is probably a gate valve with a bonnet nut. You could try tightening the nut just a little. Don't overdue it.
  4. hj
    Unless it is a valve with an "O" ring seal, tightening the nut beneath the handle should stop the leak. Do not tighten too much or the handle will not turn.
  5. jdon88
    jdon88 New Member
    Jul 7, 2010
    Pottstown PA
    Thanks, I tightened the nut and looks like it stopped.
Similar Threads: shut valve
Plumbing Forum, Professional & DIY Advice Zone valve clunks shut 47 minutes ago
Plumbing Forum, Professional & DIY Advice Help with replacing shut-off valve Feb 12, 2017
Plumbing Forum, Professional & DIY Advice Shutoff Valve Won't Open Jan 7, 2017
Plumbing Forum, Professional & DIY Advice Turned one shut off valve now there is NO water in bathroom sink. HELP Dec 24, 2016
Plumbing Forum, Professional & DIY Advice The lever (single )on the washer machine shut off valve is missing Dec 10, 2016
