Showerhead stem stuck
Discussion in 'Shower & Bathtub Forum & Blog' started by kmilhous, Nov 5, 2011.
  1. kmilhous
    kmilhous New Member
    Nov 5, 2011
    Indiana
    I'm in the middle of a bathroom remodel job and am unable to remove the shower head stem. From this picture below (taken from inside the wall) I believe it to be threaded into the 90 deg coupler, but if it is I cannot get it to budge. I've sprayed some WD-40 on it without any change. Does anyone have any suggestions on how I might remove this stem?
    thanks
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    A strap wrench.
    Unfortunately for you whoever installed that drop ear elbow didn't screw it into any blocking.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    Assuming you are replacing it, just get a 10" pipe wrench. Normally, a 12" channellock would also do it. Even though the drop ear is not secured, that should turn out. The treads on the chrome arms have been known to break,and you will have to cross that bridge when you come to it.
  5. hj
    Use a bigger wrench, or more pressure on the one you do have.
  6. jadnashua
    Remember to turn it counter-clockwise!
  7. kmilhous
    kmilhous New Member
    Nov 5, 2011
    Indiana
    Thanks. Bigger wrench took care of it.
  8. dlarrivee
    Jun 28, 2009
    Canada
    You are indeed an engineer...
Similar Threads: Showerhead stem
Shower & Bathtub Forum & Blog How can I avoid a leak from hidden flexible Handheld showerhead hose in a tub? May 22, 2014
Shower & Bathtub Forum & Blog Never ending leak on showerhead... Dec 17, 2013
Shower & Bathtub Forum & Blog Dual showerhead question Apr 24, 2013
Shower & Bathtub Forum & Blog How to increase water pressure/flow in showerheads Feb 9, 2013
Shower & Bathtub Forum & Blog Raise showerhead Feb 8, 2013
