Showerhead only trickling
Discussion in 'Shower & Bathtub Forum & Blog' started by obrien234, Jul 2, 2007.
  1. obrien234
    obrien234 New Member
    Jul 2, 2007
    Pardon my ineptitude, but plumbing is not my forte...
    The showerhead in my bathroom has all of a sudden stopped pushing out the water how it should. The water still comes through, but just as a stream going straight down from the bottom of the head.
    Is this a problem with my water pressure, or with the head itself?
  2. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    It's more likely to be a problem with the showerhead. As long as the shower valve is not turned on, you can remove the showerhead and look inside to see if it is plugged, you can also turn on the shower valve while the showerhead is removed to see if you get full pressure. If your showerhead looks to be fine, but you don't get full pressure, then the problem lies with your shower valve.
    Don't get wet!
  4. Mike Swearingen
    Mike Swearingen New Member
    Jan 12, 2005
    Independent Real Estate Broker
    On Albemarle Sound In Northeastern NC
    It could be debris from inside the water lines or minerals clogging the showerhead. Remove the showerhead and clean it out. If you see a lot of white particles, if they are soft they're minerals, if they're hard they may be debris from the water heater dip tube.
    If it is soft white stuff, soak the showerhead overnight in vinegar to dissolve it out. If they're hard little bits of plastic, repalce the heater dip tube.
    Good Luck!
Similar Threads: Showerhead trickling
Shower & Bathtub Forum & Blog How can I avoid a leak from hidden flexible Handheld showerhead hose in a tub? May 22, 2014
Shower & Bathtub Forum & Blog Never ending leak on showerhead... Dec 17, 2013
Shower & Bathtub Forum & Blog Dual showerhead question Apr 24, 2013
Shower & Bathtub Forum & Blog How to increase water pressure/flow in showerheads Feb 9, 2013
Shower & Bathtub Forum & Blog Raise showerhead Feb 8, 2013
