shower with six 2.5 gpm heads on well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by tjetson, Nov 26, 2013.
  1. tjetson
    tjetson New Member
    Oct 9, 2009
    winnipeg
    Hi,
    trying to spec a pump for my new house it has a shower with 6x2.5gpm water tile bodysprays
    should i be going with a variable speed pump for this application? i read a page saying they are a scam and break quicker not sure if that is true or not.
    what would be the best way to meet these requirements with a well pump
    thanks
  2. VAWellDriller
    VAWellDriller Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    I'll leave the variable speed debate to others...but to properly spec any well pump, you need to know the approximate pumping water level at its reported yield...and start from there. You'll want at least a 20 gpm pump....which could be anything from 1/2 to 5 HP depending on the well.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    The size of pump depends on the depth to water in the well, how many GPM’s you need at the same time, and the pressure you want to come out the showerheads.
    The trick is to be able to run as much water as you want, and still be able to use small amount of water without damaging the pump/motor, but you don’t need a variable speed pump for that.
    You can also do this with a really big pressure tank or a Cycle Stop Valve and a small tank.
    Find out how deep you are pumping from and if the well will make 20 GPM first. If the well won’t make 20 GPM, you will need a storage/cistern tank and another booster pump.
  5. tjetson
    tjetson New Member
    Oct 9, 2009
    winnipeg
    the well is 5" pvc down to 138 feet, i lost the drilling papers but at one point it was going to be used for a geothermal system that required huge ammounts of water so it should meet 20 gpm no problems
    Im meeting with an installer tomorrow just wanted to be alittle versed in it so they dont rip me off like an old lady
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Before you buy anything you need to have them test the well to determine it's true recovery rate. Without knowing that much of the equation you risk destroying whatever pump you end up choosing. Based on past posts made here, the variable speed pumps seem to have a lot of controller failures, which would cause me to shy away from them and go with a standard pump and tank system.
  7. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Huge amounts is not a measurable value and depends on many factors. Could be less than 1.5 GPM per ton.
Similar Threads: shower heads
Pumps and Tanks Well Forum & Blog. Water is life. I'm in need of a shower Sep 4, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Shower control valve removal May 18, 2015
Pumps and Tanks Well Forum & Blog. Water is life. low water pressure in upstairs shower Aug 7, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Bursts of water out of shower & faucets May 31, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Other water usage during shower ! Mar 15, 2007
