shower water temperature fluctuation problem
Discussion in 'Shower & Bathtub Forum & Blog' started by dayexday, Jul 3, 2012.
  1. dayexday
    dayexday New Member
    Jul 3, 2012
    new york
    hello, i'm having a problem with my water temperature when I shower. Whenever I turn the shower on, even at a low pressure, the water temperature will go from from hot to cold to hot without reason. it seems to be related to the water pressure b/c when it gets colder, the water pressure increases slightly even though I'm not turning the controls. the fluctuation gets worse if I turn the water on all the way so I can't use the shower at full blast.
    Any ideas what needs to be done?
    Thanks in advance for the help!
  2. Terry
    Aug 17, 2004
    Can you post a picture of the shower valve?
    New valves come pressure balanced. If you have old piping and the old non-balanced valve, then adding an expansion tank helps with pressure swings.
    If you have a pressure balanced valve and the temperature is changing, then you may need some work with the cartridge.
  4. dayexday
    dayexday New Member
    Jul 3, 2012
    new york
  5. dayexday
    dayexday New Member
    Jul 3, 2012
    new york
    i have old valves so I'm thinking I should have pressure balanced valves installed. Would you know if that require putting a hole through the wall and what that process entails? Thanks again
  6. Terry
    Aug 17, 2004
    Moen has a remodel plate for their Posi-Temp tub/shower valve. You cut the tile from the supplied template and that gives enough space for a plumber to get in there and change it.
Similar Threads: shower water
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
