Shower water runs out when opened
Discussion in 'Shower & Bathtub Forum & Blog' started by nancymarie5, Jun 25, 2009.
  1. nancymarie5
    nancymarie5 New Member
    Jun 25, 2009
    How do I fix this problem-after showering and opening shower door, water runs out of track onto floor, carpet, etc? This is a new condo with a brand new shower door.
    Thanks.
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    Is the door installed correctly. In the ones I've seen the track drain is installed towards the inside of the shower.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    With no more information than you have given us, I would agree that the track was installed inside out. The track should drain into the tub.
  5. hj
    door
    It appears to be a shower with a hinged door. Is this merely water lying on the top of the track which drains off when the door is opened?
  6. nancymarie5
    Jun 25, 2009
    HJ,
    Yes, it is an independent shower, and the water collects in the track. When I open the door, all the water collected runs out onto the floor or bathmat. Should the track be adjusted up, down, or what if it was totally closed off?
  7. hj
    track
    It may just have to be relocated so the hinged end is lower when the door is open so the water drains back into the shower. Right now it may be the opposite way, or the door may be out of plumb so the water drains the wrong way when it opens.
  8. jadnashua
    One thing to consider also is they may have made the curb either without any pitch to the inside of the shower, or, it could be level or tiled out.
Similar Threads: Shower water
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
Shower & Bathtub Forum & Blog No water in shower and tub but water everywhere else in the house Sep 23, 2016
