shower wall union
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gardner, Oct 24, 2007.
  1. gardner
    gardner DIY Senior Member
    Apr 2, 2007
    Ontario
    I have a shower head that has been installed at about chest height. It's not been worth it to tear apart and re-build the tile wall to move it to a more sensible height, so instead I've installed a hand-held shower head and bracket. This part works fine. The old shower-head tube still sticks out at chest height though, with the hose from the hand shower sticking out past that. I don't like the way the tube sticks out and so I've bought a wall union to replace it, similar to this Grohe unit.
    [​IMG]
    Now my questions:
    How do I work out the length of nipple I need between the fitting inside the wall and the union? Will I be able to get the wall union to fit flush against the tile wall?
    If I work out I need a certain length of nipple, will I be able to buy that or have it made up?
    How do I tighten the parts together? Should I tighten the nipple first, then the union on top? Or do I tighten the two parts together by turning the union?
    Is there any good strategy for preventing leaks inside the wall from the inside thread joint? Just use a bunch of pipe dope and hope for the best? It is a shower head and so doesn't carry the same pressure as a regular line and is only pressurised when the shower is running.
  2. hj
    union
    You have to give a better link than that to the picture, but you do not need a "union" you need a "wall elbow".
  4. gardner
    Apr 2, 2007
    Ontario
    I find myself unable to make a normal link work -- the BBS is replacing it with "****" -- but I've edited my posting to include the picture so you can see what it is.
    Despite the fact that the thing is physically and elbow, it is referred to as a union. Ask Google if you don't believe me.
    It has a female 1/2 NPT on the back and a 1/2 NPT on the bottom for your shower-head hose to connect on.
  5. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Is npt or (IPS iron pipe size)?
  6. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Is npt or (IPS iron pipe size)?That is IPS tapered threds.
  7. hj
    union
    Well,as the London street vendor said after he sold someone a "hot mutton pie", and was told it was neither hot nor mutton, "That isn't what it is, it is just what we call it". It is a wall elbow regardless if they call it a union. If anything the "union" would be the connection on the end of the hose that connects to it.
Similar Threads: shower wall
Plumbing Forum, Professional & DIY Advice Installing new shower rough-in. Remove more drywall? Feb 15, 2017
Plumbing Forum, Professional & DIY Advice Water Damage in wall behind bathtub/shower in Master Bath Jan 15, 2017
Plumbing Forum, Professional & DIY Advice Air Chambers, Pipe behind shower wall that just terminates Jun 28, 2016
Plumbing Forum, Professional & DIY Advice Shower controller for thin wall or ? Jun 22, 2016
Plumbing Forum, Professional & DIY Advice Gap between shower valve cover and wall Nov 3, 2015
