Shower Valve
Discussion in 'Shower & Bathtub Forum & Blog' started by CPD195, Feb 15, 2009.
  1. CPD195
    CPD195 New Member
    Feb 15, 2009
    I am replacing my bathtub with a walk-in shower and I need to raise the shower valve. I am a novice when dealing with plumbing... is this job that difficult or should I call in a pro?:confused:
  2. jadnashua
    While soldering isn't all that hard, considering that this is going to be hidden behind a wall, and you haven't done it before, you might want to have this done. Once the demolition is done, access is easy, and it shouldn't take that much time (therefore money).
    Keep in mind, though, that you'll probably need to upgrade the drain as well to 2" (it's probably 1.5" now), and most people prefer to have the drain centered in the showerpan...so, unless you've got an unusual tub, that will have to be moved as well. This may mean tearing up the subfloor, or the ceiling below (or slab).
Similar Threads: Shower Valve
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
