shower valve trim mystery
Discussion in 'Shower & Bathtub Forum & Blog' started by wallygater, Feb 17, 2009.
  1. wallygater
    wallygater New Member
    Dec 16, 2007
    long island
    I have installed a new 3/4 inch feed thermo control shower valve. It is made by BRIZO. I think they are a high end branch of delta. the valve body is in the wall, the guts went in with 4 screws, then a sealing plate / with gasket went on with 4 more screws. so far so good. after that a collar goes in with a valve stem and another screw. that went well. the final step is the finished wall plate / and then the knob goes on with a set screw. the finished wall plate has what looks like Velcro on it. the sealing plate also has the same strange Velcro on it. the strange Velcro lines up on the sealing plate and the Finnish plate. the strange looking Velcro is male on both parts so there is no bond at all. Has any one ever seen anything like this. What the hell is supposed to hold the finished plate on? I just don`t get it. Buy the way, this valve, with thermo guts, and trim kit, costs about 700. bucks retail. Are they kidding me with this design, or am I missing something?
    __________________
    wally
  2. Howard Emerson
    Howard Emerson I teach guitar:You call that a job?
    Apr 28, 2008
    Huntington Station, NY
    Hi Wally,
    The Hansgrohe unit I put in had a similar system as the one you describe. It worked very well in my case.
    They both look like 'male' Velcro, but unlike real Velcro, which is hooks and loops, these are interlocking 'sticks'.
    When I pressed down on it, it took a little effort to make it work, and I heard an obvious 'click', with the material on the Hansgrohe.
    The important thing to keep in mind is the depth at which you set the body from the tile face. Perhaps it is not quite close enough to allow for proper contact.
    I did, by the way, use clear Silicone caulk along the top edge of the finish escutcheon plate. I masked it off prior to sealing, so the caulk line is less than 1/16" wide, so hardly visible.
    HE
  4. wallygater
    Dec 16, 2007
    long island
    thank you Howard. I pressed hard on the strange Velcro and sure enough it clicked tight just like you said. Problem solved. You are a great asset to this forum and I truly appreciate the he time you spent reading my post and then solving my problem.
  5. Howard Emerson
    Apr 28, 2008
    Hi Wally,
    I'm very glad to hear that it worked out for you!
    Thank you for replying back to relate what happened............I wish more people would get back to responders so that the advice given can be judged to have been helpful or hopeless:)
    Regards,
    Howard
    http://www.howardemerson.com/
Similar Threads: shower valve
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
