Shower Valve Supply Confusion - GPM/Rate of Flow
Discussion in 'Shower & Bathtub Forum & Blog' started by Erc, Apr 15, 2011.
  1. Erc
    Erc New Member
    Mar 21, 2011
    ATL Georgia
    I'm currently in the planning stages of a custom shower. I was looking at the Delta thermostatic valves all of which are supplied by 1/2''. If I couple that with a 3 port 6 setting diverter and given good water pressure, is that 1/2'' line sufficent to run multiple 2.5 GPM outlets? Say a rain shower and a hand shower? And say I run this same setup at the other end of the shower and (hot water aside) occasionally 4 outlets are running at the same time? I have 3/4'' supplies coming to the bathroom currently. Delta doesn't give any GPM or rate of flow info on any of there rough valves that I can find.
    Delta appeared to have better performance reviews on this forum as opposed to Moen and Kohler both of which offer 3/4'' valves.
    Any input is much appreciated?
    Thanks
  2. jadnashua
    I wouldn't plan on more than around 5-6 gpm on a 1/2" supply. Some of this is a restriction on the water flow velocity. If your pressure is quite high, you can flow a bit more, but you'll have long term problems as the faster the water flows, it can start to erode the pipe and fittings from cavitation and friction. Most 3/4" valves are capable of about double that flow. Depending on your pressure, you may not be happy with 2- 2.5gpm showerheads...depends on the design. More, is just asking for problems. Few of the valves have full-port openings, so act as a restrictor.
Similar Threads: Shower Valve
Shower & Bathtub Forum & Blog Old delta shower valve not working Today at 6:30 AM
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
