Shower Valve Solder Leak
Discussion in 'Shower & Bathtub Forum & Blog' started by Hillel, Aug 3, 2014.
  1. Hillel
    Hillel Member
    Sep 26, 2007
    Cleveland, OH
    It appears that our master shower has a leak in the solder to the pipe which goes to the shower head. You can see the leak shooting out as a tiny jet in the picture below. This was installed by a professional plumber two years ago. There is not much room to work with the pipe above the valve in the open hole from the shower handle. Can this be re-soldered in place by just adding solder? The alternative would be to cut the wall from the closet behind to have enough room to cut the pipe, pull it out, solder it fresh, and insert a repair coupler.
    Thanks,
    ---Hillel
  2. hj
    There is no such thing as a simple "small" leak. The only way it can leak is if the entire joint is compromised and poorly done. It has to be removed and redone.
  4. Terry
    Aug 17, 2004
    When we pull bad joints apart, often there is a lack of solder inside the joint. Trying to add solder outside of that joint is like patting someone on the back and expected to fix an ulcer.
  5. jadnashua
    A leak like that, once it has water contaminating it, like was said, needs to come apart, be thoroughly cleaned, and then resoldered...you will not be able to get solder to flow properly with the contamination.
    IT could have been caused by not fully cleaning the joint, overheating it and burning the flux, not heating it enough or evenly, and probably a few other reasons. A valve body has a fair amount of mass, and if you do not move your torch around to get it from all sides, the solder may not flow properly to fill in the joint.
Similar Threads: Shower Valve
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Thursday at 4:46 AM
Shower & Bathtub Forum & Blog Shower mixing valve Thursday at 12:24 AM
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Upgrade Manufactured Home 2 Handle Valve with Bath Shower spout and diverter Jan 11, 2017
Shower & Bathtub Forum & Blog Can Anyone Identify the Brand of this Shower Valve Body? Jan 4, 2017
