Shower Valve Rough, use union or not
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lmei007, Nov 6, 2013.
  1. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    I just found the shower rough in I have is thread type. I would like to be solder type.
    I am a little worry about the leaking from the threaded joint after everything is there. One way to relieve this is use it with union.
    Do you think it is good idea to add an union there?
    thanks,
  2. Terry
    Aug 17, 2004
    You can either solder in the male adapter to the body,
    or solder a male adapter onto pipe first, dope and thread in.
  4. hj
    Using a union just gives you three more places it could leak.
  5. dj2
    dj2 Well-Known Member
    Aug 13, 2013
    California
    Plumbers have been installing threaded and sweat for years - done correctly they both have the same durability. You don't need unions.
    Just remember to remove the cartridge if you sweat.
  6. lmei007
    lmei007 Member
    Sep 21, 2007
    Maryland
    a special adapter? I tried the 1/2" pipe. It cannot being plug into the body.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    One way to do this is to solder a piece of pipe to a 1'2" male adapter. Then screw the adapter into the valve body. Then solder the rest of the fittings and pipe. This avoids getting the valve body too hot. This adapter is not really a "special" adapter, accepts a 1/2" pipe into one end and has 1/2" thread on the other. Very common, just ask for a 1/2" male adapter.
Similar Threads: Shower Valve
Plumbing Forum, Professional & DIY Advice ProPEX shower valve instalation Tuesday at 10:13 AM
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Moen Shower Valve is stiff. Jan 16, 2017
