Shower valve Question
Discussion in 'Shower & Bathtub Forum & Blog' started by robofvancleave, May 30, 2005.
  1. robofvancleave
    robofvancleave New Member
    May 28, 2005
    I would like some help with a problem, to make a long story short I had hot water invading my cold water, the source was tracked down to a Moen shower valve, I have tried replacing the stem, with no results, looking at the parts list I see what is called a stop check valve, I have remove these and can see no use for them, I noticed in another model in the catalog it appears to have a spring and mine don’t
    I cannot find them locally, and before ordering them I just wanted to know if this is the problem or could it be the valve just gone bad.
    The valve is a Moen single handle, about 30 years old, and has the stop check valves on both sides, brass stem with o-rings. Pull out to cut on.
    Edit: I called Moen today, and was asked what stem that I put in and told them a brass one just like the one that come out, they said to try a plastic one, mod. 1225 and it shoud solve the problem. Any thoughts, before I order the part.
    [​IMG]
Similar Threads: Shower valve
Shower & Bathtub Forum & Blog Old delta shower valve not working Saturday at 6:30 AM
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
