Shower Valve Question
Discussion in 'Shower & Bathtub Forum & Blog' started by dkn, Feb 22, 2005.
  1. dkn
    dkn New Member
    Jan 20, 2005
    Just finished tub and shower remodel. When i went to install shower valve estucean and handle there is a larger gap between handle and cover than i think there should be ( about 1.5 - 2 inch ). I am not sure if this is correct or do I need to put the plastic back on valve first. The valve is a moen. I hope this makes sense.
    Thanks for the help, doug
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    Single control valve?
  4. hj
    valve
    The distance from the handle to the round trim plate varies depending on how far the valve was installed in the wall. As long as you have the "stop" tube around the brass barrel so it shows between the ring and the handle you have it assembled correctly.
Similar Threads: Shower Valve
Shower & Bathtub Forum & Blog Moen Chateau, Which shower trim fits this valve? Mar 16, 2017
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog Old delta shower valve not working Feb 25, 2017
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
