Shower valve plaster ground depth.
Discussion in 'Shower & Bathtub Forum & Blog' started by DaveB, Jan 6, 2007.
  1. DaveB
    DaveB New Member
    Jan 1, 2007
    Just had a plumber install my new Moentrol shower valve (replaced existing)...The depth of the plaster ground guide is only 1/8" beyond the framing which will make it almost 3/4" short of the finished tile surface.
    If I pop out (2) supply line spacers through the drilled wall studs, I can pull forward the valve to the perfect position, but the 1/2" hot & cold supply lines will be touching the wall framing...Any issues with that?
    Dave
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Figure out where the finished wall is going to be and thats where it belongs.
  4. DaveB
    DaveB New Member
    Jan 1, 2007
    I know where it belongs, my question would be if it is ok for the supply lines to "touch" the stub (rub wear).
  5. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    If they're touching wood I don't see a problem... if it bother's you that they might rub then put a clamp on it or remove some of the wood with grinder or chisel.
  6. Cal
    Cal New Member
    May 10, 2005
    Northern Virginia
    Dave ,
    Moen makes an extension kit for just such a problem. It has longer screws ,trim ring and handle extension.
    You can install at time of trim installation . Or get the plumber back to put the valve body in at the right depth.
  7. DaveB
    DaveB New Member
    Jan 1, 2007
    Doesn't that trim give ONLY 1" extension (no more / no less)? I've pulled the plumbing forward enough that it the plaster ground will be about 3/16" short of being flush w\ the finished surface...Hoping that will be OK.
    Dave
Similar Threads: Shower valve
Shower & Bathtub Forum & Blog Old delta shower valve not working Today at 6:30 AM
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
