Shower valve - open/closed reversed
Discussion in 'Shower & Bathtub Forum & Blog' started by slimjones, Jan 26, 2009.
  1. slimjones
    slimjones New Member
    Jan 26, 2009
    Sorry if this is a newbie question.
    I had a shower valve installed by a professional plumber.
    After tiling the shower stall myself, and installing the fixtures, I found that the cold water valve opens by turning clockwise and closes by turning counterclockwise. Exactly opposite of what I would expect. The hot water valve works correctly.
    How can I correct this problem?
    TIA - Slim
  2. jadnashua
    Some manufacturers provide the valves in left-hand and right-hand versions so the handles move symmetrically. If you want both the hot and cold to turn the same way, you probably need a different brand or style. It's more noticable on a sink...to turn the water on with lever handles, you move the levers towards the spout - one going clockwise and the other counter-clockwise...same as what you have now on your shower (if I undertood you correctly). So, I don't think it is an error, it is a design decision.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    What kind of handles do you have?
    Knob, lever, cross....
  5. slimjones
    Jan 26, 2009
    They're cross handles. It's a Concinnity fixture.
  6. Redwood
    Dec 15, 2007
    Service Plumber
    Ohhh Boy!
    I'm sorry to hear that you put that valve in your wall...
    They went out of business a couple of years ago...
  7. hj
    faucets
    Many "aftermarket" manufacturers send ALL faucets with the stems for lever handles which rotate the way yours does. In some cases a clip can be removed and reversed to change the rotation, but in most cases the stem has to be replaced with the proper one.
  8. slimjones
    Jan 26, 2009
    re: Concinnity - what can you do ? I bought it years ago and it is a very nice fixture. It cost me some $$ and I'm going to use it until it wears out.
    I'll take a closer look at the valve and see if there's a way to reverse it.
    Thanks for all the advice, this really is a great forum.
    -Slimjones
  9. hj
    faucet
    Depending on what controls the degree of rotation, removing the small "C" clip and installing it on the other side might do it.
Similar Threads: Shower valve
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
