Shower Valve installed too far forward
Discussion in 'Shower & Bathtub Forum & Blog' started by jinmalibu, Aug 14, 2014.
  1. jinmalibu
    jinmalibu New Member
    Jul 24, 2011
    Malibu, CA
    Recently remodeled my bathroom. A new Kohler Rite Temp K-304 valve was installed. After the shower was tiled we discovered that the valve was installed too far forward so the escuctheon that fits over the valve will not fit flush against the wall, which is what the instructions call for. There is a gap of about 3/16" to a 1/4" and I believe the valve is a little twisted, however, I can't guarantee the wall is plumb as not much in this house is.
    It is possible to access the valve from behind the wall. Is it possible to loosen up the valve and move it back so the escutcheon will seat against the wall?
    [​IMG]
    http://terrylove.com/forums/index.p...hler-rite-temp-bath-shower-valve-k-304.41581/
  2. ShowerDude
    ShowerDude Showers
    Apr 7, 2014
    Minnesota
    Cut a small hole in wall from behind and take a peek and a picture, depends on how your plumber installed and secured things.
    I assume your kohler trim escucion threads on amd is timing out?? Can your plumber come back and fix it?
    Wait for terry or hj see what the say....
  4. hj
    being too far forward almost always means the valve has to be repositioned, but which trim are you using, since some trim plates are thicker than others, and depending on its diameter, some manufacturers have auxiliary trim rings that fit behind it to add depth, and might fit your trim.
Similar Threads: Shower Valve
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
