shower valve identification
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lati_cz, Jan 7, 2011.
  1. lati_cz
    lati_cz New Member
    May 16, 2009
    Sunnyvale, California
    does anyone know what type/model is this shower valve? thank you Michal
  2. jimbo
    jimbo Plumber
    I don't recognise the handle right off. Someone probably will....just hang with us. It could be a Delta 1300 series, but the escutcheon should say "delta" on it. The fact that there is no name,...it could be any one of dozens of knockoff imports.
  4. hj
    This is a case where a picture of what is UNDER the chrome plate would be more helpful than the picture you have now. It has some features of a PricePfister, but I have not seen any with a "lever handle" like that.
  5. lati_cz
    lati_cz New Member
    May 16, 2009
    I'll post more pics on Monday.
    thank you Michal
  6. Terry
    Aug 17, 2004
    You will need to pull the handle and take a picture of the stem.
  7. lati_cz
    lati_cz New Member
    May 16, 2009
    more pics here:
  8. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Well you've gone ahead and cut out the valve, I hope you plan on replacing it with a Moen or Delta unit.
  9. lati_cz
    lati_cz New Member
    May 16, 2009
    No I still need to figure out what it is. I remodel 2 baths - one get new valve, other will keep existing. HO wants leave the valve and just change the plate and handle. Anyone? Thank you Michal
  10. lati_cz
    lati_cz New Member
    May 16, 2009
    Btw. is it common practice not to use teflon tape/sealant on adapter threads and just fill those with melted silver instead? I noticed it on both valves - never seen it before.
  11. hj
    A "straaight on view" is not a lot of help, especially when the lock nut is still attached. Remove the cartridge and give us a "good" side view, and also the bottom because the configuration of the ports is often as distincitive as the cartridge itself for identification purposes. Also, does the handle just rotate from off to cold to hot, or do you set the temperature by rotating it and then turn it on by lifting or pulling the handle?
  12. lati_cz
    lati_cz New Member
    May 16, 2009
    HJ - it rotates and pulls
    more pics, hope it helps. If better quality is needed I'll use better camera tomorrow
    thank you Michal
  13. jimbo
    jimbo Plumber
    go here www.alfanoplumbingparts.com, look at the single handle cartridge catalog. See if you can identify it. You have one of a million no name cartridges which all look very much alike.
    Pay close attention to the shape of that white gasket stuck inside the bottom of the valve body. They are uniquely shaped in the different brands.
  14. hj
    Looks like the Sayco 7006 with the square handle adapter. It looks like the same one that Concinity uses. Websone and Sayco also have similar versions which rotate for temperature and tilt up for volume.
  15. rszeller
    rszeller New Member
    Sep 20, 2012
    Boston, MA
    see the attached photos of thermostatic mixer only. Any ideas anyone? valve1.jpg valve2.jpg
  16. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
  17. hj
    Or Hansgrohe, which is a different company. But the "trident" handles are often a Grohe feature.
  18. rszeller
    rszeller New Member
    Sep 20, 2012
    Boston, MA
    Yes, it is installed sideways. I think that threw me off. Thanks
  19. ddodson
    ddodson New Member
    Nov 11, 2012
    Oregon
    Have the same or similar with a slow drip I'd like to fix.
    This is as far as I've gotten with dismantling. Not sure what the next step is. Suggestions?
  20. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    You are correct
  21. rszeller
    rszeller New Member
    Sep 20, 2012
    Boston, MA
    Valve handle on this older American Standard spins cold hot off, cold hot off, etc. just keeps on spinning. Any idea as to cartridge replacement? Or maybe just handle?
Similar Threads: shower valve
Plumbing Forum, Professional & DIY Advice ProPEX shower valve instalation Yesterday at 10:13 AM
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Moen Shower Valve is stiff. Jan 16, 2017
