Shower Valve Body Installation (NPT)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hans_idle, Jan 24, 2008.
  1. hans_idle
    hans_idle New Member
    Sep 16, 2007
    Sitting on my butt at a desk all day
    Princeton Junction, NJ
    This seems like such a simple problem, but I'm at a loss as to how to deal with it.
    My wife just purchased a Jado shower head and valve body (pressure balanced). The inlets and outlet are 1/2" NPT. How the heck do I thread the copper supply pipes onto this? The supply line is always going to be immovable.
    The supply lines are fixes in place, so they can't turn. If I thread-on an adapter and then solder to the copper pipes, how do I know if I've gotten the adapter tight enough? I'd have to turn the water on to find out, and by then it's too late.
    What am I missing? This seems like such a simple issue, given that a lot of valve bodies come with this type of hookup.
    -Hans
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Solder pipe to adapter
    mount faucet
    install adapters w/pipe to faucet
    then pipe to faucet.
  4. hans_idle
    Sep 16, 2007
    Thanks. I had done a search here, but my search terms were too vague and I got too much info. A search on the internet yielded a few clues that agree with what you listed.
    I suppose the key is knowing how tight to make the connections to the valve body, and making sure to use pipe compound.
  5. Terry
    Aug 17, 2004
    For thread sealant, I like something like rectorseal with Teflon paste.
    The trouble with tape is that heating the pipe a ways a way can affect it.
    When threading a MA into a valve, I crank it in pretty darn good.
  6. remodelbob
    remodelbob New Member
    Jun 30, 2005
    Washington
    can't you also slip 1/2" copper into the shower valve and just solder it on there?
    i know the kohler ones work like that. you can either use the npt or solder.
  7. hans_idle
    Sep 16, 2007
    For some reason, Jado builds their faucets to NOT allow the soldering on the inlets and outlets. You can't fit the 1/2" inside and it specifically says not to try it.
  8. jadnashua
    The quality of the threaded fittings these days is often pretty crappy. It might be worth paying the extra for a brass one if you can find one with nice clean threads.
  9. hans_idle
    Sep 16, 2007
    I'll look for brass. Any issues with soldering copper to brass? I've done it before, just not sure if i've done it right :D
  10. jadnashua
    Copper solders just fine to brass...
Similar Threads: Shower Valve
Plumbing Forum, Professional & DIY Advice New shower / check valve question Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Plumbers- your preference for tub and shower valves/ faucets Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Moen Shower Valve is stiff. Jan 16, 2017
Plumbing Forum, Professional & DIY Advice Replacement Shower Valve Jan 2, 2017
