Shower/tub temp. not hot enough
Discussion in 'Shower & Bathtub Forum & Blog' started by jackb, Nov 30, 2008.
  1. jackb
    jackb New Member
    Nov 30, 2008
    Hi,I'm having trouble getting hot water in my upstairs tub/shower-It's lukewarm at best and it's good and hot everywhere else in the house including the sink in the same bathroom.The tub/shower control is a Symmons Temptrol unit that was installed in 1988.I thought that the problem would be in the spindle unit(I have well water and I had to replace this once before)but it did not help things.Also,I tried adjusting the anti-scald set-screw(I backed it way out so it is not even contacting)but this did not help either.What else might it be?A clogged pipe?Thanks very much for any advice.
    http://www.symmons.com/Customer-Service.aspx
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    a partly blocked hot water line could be the problem. I would really suspect the old valve. Replace with a Delta and you will probably be fine.
Similar Threads: Shower/tub temp
Shower & Bathtub Forum & Blog Shower/Tub loses pressure as hot water temp increases Oct 21, 2010
Shower & Bathtub Forum & Blog Problem with lukewarm temp on Pegasus 1/4 turn 1 handle shower/tub Dec 3, 2008
Shower & Bathtub Forum & Blog Shower/Tub temperature Mar 15, 2005
Shower & Bathtub Forum & Blog Sterling ensemble curve shower/tub surround Oct 5, 2016
Shower & Bathtub Forum & Blog Recommendations for new shower/tub hardware............ May 31, 2016
