Shower/tub plumbing
Discussion in 'Shower & Bathtub Forum & Blog' started by bobv, Sep 4, 2007.
  1. bobv
    bobv New Member
    Sep 4, 2007
    Higher Education
    Ada, OK
    I am installing a jetted tub in a three wall alcove with a shower surround. I would like to deck mount a spout in the front corner of the tub deck instead of on the wall and use a single handle wall mounted control valve to control the tub fill and shower.
    I was reading somewhere about limiting the distance from the valve to the spout to 18" prevent what I think they called "water rise" causing water to come out the shower head when filling the tub. I have seen a Kohler valve that has the diverter mounted at the valve, but it has instructions not to use multiple elbows, or PEX between the valve and the spout.
    Does anyone have suggestions or should I re-think my plan?
    Bob
  2. Furd
    Furd Engineer
    Jul 3, 2007
    Retired energy systems engineer
    Wet side of Washington State
    I would think that if you increased the size of the pipe immediately after leaving the valve assembly that you could alleviate this problem.
    Most valves have 1/2 inch outlets so I would go immediately to a 3/4 inch pipe all the way to the remote spout. I don't know if "they" make a spout that uses a 3/4 inch connection but if you could find one it would be preferable to reducing back to 1/2 inch at the spout.
    HOWEVER, I am not a plumber and I have never tried this...but I might. :eek:
Similar Threads: Shower/tub plumbing
Shower & Bathtub Forum & Blog What do I need...Plumbing fixtures for shower/tub Oct 10, 2013
Shower & Bathtub Forum & Blog Sterling ensemble curve shower/tub surround Oct 5, 2016
Shower & Bathtub Forum & Blog Recommendations for new shower/tub hardware............ May 31, 2016
Shower & Bathtub Forum & Blog Single handle shower/tub valve recommendations for good flow rate? Jan 30, 2016
Shower & Bathtub Forum & Blog Three Handle Diverter - Changing Shower/Tub Diverter Turn Direction Dec 26, 2015
