Shower/Tub loses pressure as hot water temp increases
Discussion in 'Shower & Bathtub Forum & Blog' started by JOEG2321, Oct 21, 2010.
  1. JOEG2321
    JOEG2321 New Member
    Oct 21, 2010
    Akron, Ohio
    I currently live in a condo that is roughly 7 years old and have had nothing but problems with one of my showers. I have not had a single problem in the other bathroom whether in the sink or the shower. My particular problem is that when i turn on either the shower head or the faucet to run bathwater the water pressure is fantastic. However as I begin to make the water warmer, the pressure drops off drastically to the point where it seemingly takes forever to run a hot bath, or take a hot shower. Also worth noting is that the sink in the same bathroom as the problematic tub/shower works perfectly. I am essentially just looking for a quick fix, and or an inexpensive fix before i begin taking things apart and investigating further. Any information can help at this point.
  2. jadnashua
    Keep in mind that as you first start out, you are getting cold and hot mixing; then, as you try to make it hotter, you start decreasing the amount of cold. At the warm temp, you are getting the full flow of both hot and cold supplies, but as you approach all hot, you only have the hot line. This could be a supply thing, as the hot line, especially if it has any galvanized steel pipe in it, if probably rusting, which can close off part of the flow. It may never happen, but if it does, often starts on the hot side. Do you ever get any rusty water out of the valve, especially at the start (it often clears out after a little flow to purge it)? If the valve has in-line shutoffs, the hot shutoff might not be fully opened. Or, there could be some crud lodged in the cartridge, or (if it has one) the inlet filter screen could be clogged, reducing the flow.
Similar Threads: Shower/Tub loses
Shower & Bathtub Forum & Blog Sterling ensemble curve shower/tub surround Oct 5, 2016
Shower & Bathtub Forum & Blog Recommendations for new shower/tub hardware............ May 31, 2016
Shower & Bathtub Forum & Blog Single handle shower/tub valve recommendations for good flow rate? Jan 30, 2016
Shower & Bathtub Forum & Blog Three Handle Diverter - Changing Shower/Tub Diverter Turn Direction Dec 26, 2015
Shower & Bathtub Forum & Blog Bleach/chlorine smell in new shower/tub only (not in the rest of the house) Oct 13, 2015
