Hello all. I have a leak in my Shower. I can run the water in the tub with no issues but once I pull the knob on the tub spout I get water leaking out from where the tub meets the wall. That tells me the leak is at or above the spout.
How is the water diverted? Is there a valve at the spout that diverts it or is it located farther up?
I plan to open the wall from the other side as the shower is tile and the back side of the wall is drywall and inside a closet so that would be less work after the fix. Can this kind of leak be fixed from the backside? I'd prefer not to destroy the tile.
I plan to open the wall up as high as the spout and if that is not the area go up to the faucet. I'm hoping the leak is not any higher than the faucet because I get in to shelving up that high.
Plan is to hire a plumber to make the repair once I identify / expose the leak.
Any advice is appreciated.
