Shower trim kit for Delta 1500/1700
Discussion in 'Shower & Bathtub Forum & Blog' started by JohnBob, Feb 20, 2007.
  1. JohnBob
    JohnBob New Member
    Feb 20, 2007
    We are finishing a remodel our guest bathroom. The house was constructed in 1996 and the bathtub has a Delta Monitor single handle faucet with separate volume and temperature controls. The finish is shot and we want to replace it and in a stainless steel or brushed nickel finish. The cartridge needs replacing as well since it leaks a little from the faucet. The problem is we can't find anything even at our local plumbing supply. They tell me it is a model 1500 with a 1700 trim. Lowes has a kit from Danco, but it looks crummy and cheap and is not the correct handle. The cartridge has a hexagonal lug where the handle engages and all the new Delta stuff uses splines instead of the hexagonal lug. Does anyone have any idea where we can get just a trim kit to fulfill our wishes? Certainly that would be cheaper than getting a plumber to do this (I think there is enough room to pull and replace the valve through the tile hole behind the big trim plate without cutting a hole in the hallway wall to access from behind)???
  2. Cass
    Cass Plumber
    Nov 12, 2005
    You need to find a plumbing supply house that sells Delta. The new valve trim will fit the old valve but it comes with a new style cartridge that won't fit your old valve.
  4. JohnBob
    JohnBob New Member
    Feb 20, 2007
    Thanks Cass, but the plumbing supply house I was in does sell Delta and I spoke not only with three salesmen, but also went back and talked with the sales manager who has nearly 20 years experience and he explained the problem to me as Delta has changed all their valves in the last 6 months and nothing of the new works with the old. So if I correctly follow what you posted, I still can't interchange new trim with the old valve even if I go for a new cartridge because the new cartridge won't fit the old valve. In other words, I still need to get an entirely new valve, cartridge and trim...right? By the way, the new style handles engage on a splined stem on the cartridge whereas as the old style handle engages/mounts on a hexagonal stem on the cartridge...they do not appear interchangeable.
  5. Dan Pick
    Dan Pick New Member
    Feb 11, 2007
    Plumbing Sales
    Speedway, IN
    JohnBob
    It sounds like you have the "Old Style" 1500 Monitor valve. Are the two screws that hold on the escutcheon both at the bottom or are they at 2 and 8 0'clock?
    If they are 2 and 8 a new 1700 series trim kit should fit. If they are both at the bottom you can only get replacement parts.......i.e. no stainless or pearl nickel.
  6. JohnBob
    JohnBob New Member
    Feb 20, 2007
    Thank you for your reply Dan. Indeed, the screws that hold the escutcheon plate are at a diagonal at 2 and 8 o'clock. So where do I go to get a 1700 series trim kit? Do I go to the Delta website since my local supplier apparently doesn't know that a 1700 series trim kit exists?
  7. prashster
    prashster New Member
    Dec 7, 2005
    Find another supplier. The Monitor 1700 is common.
  8. Dan Pick
    Dan Pick New Member
    Feb 11, 2007
    Plumbing Sales
    Speedway, IN
    Call 1 800 345-Delta and they should be able to give you the correct RP (reapir parts) numbers.
  9. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    1500 to 1700 conversion kit
    it should be pretty easy to get the conversion
    kit for the 1500 faucet....
    if you just wanted the trim for a delta 1500 faucet
    I still have those laying around....in chrome ..
    your only problem is wanting to change it to brushed
    SS or Nickle... that could be a big problem...
    if you stuck with the common chrome its easy as pie..
  10. Cass
    Cass Plumber
    Nov 12, 2005
    If you can't find a SS trim kit PM me and I can get it for you.
  11. hj
    Delta
    Delta has changed their faucets, but from what I can see, the visible parts are all the same as the old ones. Even the internals seem to be the same, the only difference being that the body in the wall that needs "adapters" to make the various versions work.
  12. Sammy Jay
    Sammy Jay New Member
    Mar 13, 2009
    Call Delta
    If you are the original home owner, (they will ask that and what you use to clean it DON'T say any type of cleaners they say only a soapy rag or it will void the warranty) delta will send you the conversion kit with the valve and chrome trim for free then you have to find the stainless trim. I just did it on two in my house built in 1997 so it is probably common after 10 years to need a rebuild. I'm not a plumber but it was easy to do I just had problems getting the bonnet nut off and delta said to soak a rag in vinegar and wrap it around the nut it didn’t work so I put heat to the bonnet nut and gently used a pair of channel locks. A new nut comes with the kit. Hope this helps.
    Sam
  13. filip0601
    filip0601 New Member
    Oct 20, 2012
    Cleveland, Ohio
    1500 series trim
    I know it is 5 years later, but if by any chance you still have a new old stock 1500 series trim available , I would be interested. I too have a gold ugly one and it feels expensive to change from 1500 to 1700 when everything works. I just want to upgrade the look. Thank you.
  14. kdharvey
    kdharvey New Member
    Jul 30, 2015
    Pennsylvania
    Hello Master Plumber Mark...I know this is an old post. Any chance you still have rim for the delta 1500 faucet?
  15. Master Plumber Mark
    Feb 6, 2005
    I probably can scrape it up somewhere.... I know I got the faceplate and the handles laying around....
  16. Terry Newton
    Terry Newton New Member
    Nov 2, 2015
    Hot Springs National Park
    Hello master plumber Mark. I too need a series 1500 faceplate and handles for a delta shower monitor. Got any?
  17. Stephanie D
    Stephanie D New Member
    Nov 1, 2016
    Virginia
    Master Plumber Mark, if you have any more trim kits in chrome, I need one! PM or email me (sdupaul@richmond.edu). Thank you!
  18. Master Plumber Mark
    Feb 6, 2005
    I will have to look into my junk pile , I KNOW that I have the face plates but they come with the install screws below the handle and they also come with the screws on the face plate with one of them at about 2oclock and the other one about 8 o clock
    let me know which ones you need
  19. Stephanie D
    Nov 1, 2016
    Virginia
    I need the old faceplate, which had the install screws below the handle (at about 5 oclock and 7oclock) and the bonnet nut and handle - basically everything you see. It's ridiculous that Delta can't help with this!
  20. Stephanie D
    Nov 1, 2016
    Virginia
    Found the handle, etc., here, now all I lack is the silver face plate - the older one with the two screws on the bottom. Also, the older ones are about 1 inch proud of the wall - the newer ones are flatter, and it looks like the hole isn't quite as large. My fingers are crossed that you have one!
Similar Threads: Shower trim
Shower & Bathtub Forum & Blog Moen Chateau, Which shower trim fits this valve? Mar 16, 2017
Shower & Bathtub Forum & Blog Help identify tub/shower trim Feb 3, 2017
Shower & Bathtub Forum & Blog ID Shower and Tub Cartridge/Trim Jan 2, 2017
Shower & Bathtub Forum & Blog Tub and shower valve/trim recommendations Sep 22, 2016
Shower & Bathtub Forum & Blog Nibco Series 600 unit Help identifying shower valve/trim Sep 6, 2016
