Shower trap out of three 90 degree ells?????
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dtraster, Oct 11, 2013.
  1. dtraster
    dtraster New Member
    Sep 30, 2013
    Wichita, KS
    Is this permitted? Is it advisable?
  2. dtraster
    dtraster New Member
    Sep 30, 2013
    Wichita, KS
    Here's what I think I'll end up using. Does this seem like a workable solution?
  4. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    Were is the vent?
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Code:
    One of the elbows could be a street, but yea, it's fine.
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Hopefully that is a vented lav drain coming into the other side of the wye, or you have much bigger problems.
  7. dtraster
    dtraster New Member
    Sep 30, 2013
    Wichita, KS
    First, almost none of this is glued... this is a preliminary dry fit--so I can make almost any needed changes. I'm trying to figure out the layout before I start framing.
    It's my understanding that the vent for a 2" drain line can be several feet from the drain itself. In any event, this is a shower drain in the middle of the bathroom floor. The drain will flow to a 4x4x2 wye that will be vented to the roof. The top picture shows the drain line butting up against a 2x10 floor joist on the opposite wall. That drain line is for the sink and will go through the joist and up to the sink. I THINK that the 2" drain is adequately vented in this layout, BUT I'm thinking that even if it is "adequate" the better approach would be to extend a vent from the sink drain, up through the far wall into the attic, and then over the top of the bathroom back to the vent stack.
    The second photo shows the proposed drain from the toilet.
    Here are two photos of the layout as I have it conceived now...
  8. Terry
    Aug 17, 2004
    The lav will need to be vented. Whether it goes up through the roof, or ties back to the first vent is up to you.
  9. dtraster
    dtraster New Member
    Sep 30, 2013
    Wichita, KS
    Thank you Terry. I seem to recall that a 2" line could be up to 6' from the vent, which is just how far away the lav drain will be, but that's evidently my faulty memory at work. But even if it were permissible, there's no real reason not to do it so that what I was planning.
    And, BTW, this is a great site and you're providing a valuable service. It's appreciated.
  10. jadnashua
    FWIW, since the socket or hub of the fittings is tapered, dry fitting will almost always result in an incorrect final result...when you add the cement, you literally melt the plastic, and the pipe will go deeper into the hub, making any of what you thought were careful measurements and cuts progressively off with each fitting down the line.
  11. dtraster
    dtraster New Member
    Sep 30, 2013
    Wichita, KS
    I'm aware that dry fitting isn't accurate. I was only going for the general idea here. I may have sacrificed a length of 2" pvc by cutting it too short but it seemed worth it to make sure that what I saw in my mind was really going to work and to get input from you all to make sure I wasn't out in left field on basic layout... And, I'm sure I'll be able to find a use for the pipe even it it is too short.
    That said, I can't thank all of you enough for your help.
Similar Threads: Shower trap
Plumbing Forum, Professional & DIY Advice Shower p trap and vent advice Saturday at 12:21 PM
Plumbing Forum, Professional & DIY Advice Shower p trap need help Mar 3, 2017
Plumbing Forum, Professional & DIY Advice Is this shower p-trap j-bend backwards? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Shower p-trap is receiving debris and smell Oct 8, 2016
Plumbing Forum, Professional & DIY Advice Shower P-Trap Above Unheated Garage Mar 28, 2016
