Shower trap install?
Discussion in 'Shower & Bathtub Forum & Blog' started by Rod M1, Mar 29, 2009.
  1. Rod M1
    Rod M1 New Member
    Mar 5, 2005
    Michigan
  2. hj
    drain
    1. It appears to be a bathtub drain not a shower.
    2. You not only have a drum trap, but it is installed as an "S" trap.
    3. As it sits, there is no way to make it legal or acceptable, because there is no vent, and any trap you install will automatically become an "S" trap, subject to all the problems that causes.
    4. This is not a DIY job, and even a plumber could have problems installing it correctly.
  4. Rod M1
    Rod M1 New Member
    Mar 5, 2005
    Michigan
    Thanks for the fast reply. My situation is the trap is plunged up and in trying to remove the clean out plug with no luck the part in the photo come loose just like you see it. No nut farrow or anything I guess just sitting with putty for the least 20 years +. What will I need to fix that connection?
  5. jimbo
    jimbo Plumber
    Most likely the end of that brass tube you see USED to be threaded. It snapped of at the root of the thread....the broken part is still inside the tee. You have a bit of work cut out for yourself here.
Similar Threads: Shower trap
Shower & Bathtub Forum & Blog How can I tell if my shower has a p-trap? Nov 6, 2016
Shower & Bathtub Forum & Blog Replacing shower drum trap Oct 21, 2016
Shower & Bathtub Forum & Blog No p-trap for new shower, contractor says OK Oct 14, 2014
Shower & Bathtub Forum & Blog Hole in shower p trap Aug 2, 2014
Shower & Bathtub Forum & Blog Is this an acceptable P-Trap design for a shower drain? Jun 13, 2014
