Shower & Toilet Flush - Pressure Question
Discussion in 'Shower & Bathtub Forum & Blog' started by LesMan, Nov 8, 2008.
  1. LesMan
    LesMan New Member
    Jan 14, 2005
    Cleveland, OH
    I am on "city water" and do not have a PRV on my line (as far as I can tell.)
    I do have a water softener (since our city water is still pretty hard.)
    When I measure "static" water pressure in the shower at the highest point in the house - with nothing on - I measure 75psi.
    Then - when I turn on a faucet in the same area - the pressure will maintain around 65psi.
    When I turn on the clothes washing machine - the pressure will drop down to 30psi.
    But - when I flush the toilet (older Kohler Rochelle "silent" toilets) the water pressure will drop down to 20psi or in some cases as low at 15psi.
    Is there anything I can do to maintain higher water pressure in the shower when the toilets are flushed?
    I would rather not replace the toilets... but if there's some kind of flow / pressure restricting device I could put on them... I would do it.
    Thanks!!
  2. hj
    pressure
    The first thing to do is operate the faucets so you only have the 30 psi, then push the BYPASS button on the softener and see if the pressure goes back to normal. If it does, and since you do not seem to have a pressure regulator it should, then you have a plugged water sofener.
Similar Threads: Shower Toilet
Shower & Bathtub Forum & Blog Advices needed : Toilet and shower drain Nov 20, 2015
Shower & Bathtub Forum & Blog Leak under shower/toilet slab area Mar 15, 2015
Shower & Bathtub Forum & Blog mini shower/toilet waterproof Mar 6, 2013
Shower & Bathtub Forum & Blog Cracked Cast Iron Stack or junction between toilet and shower Sep 20, 2011
Shower & Bathtub Forum & Blog Help: Hear toilet flushing and smell poo through shower. Aug 10, 2010
