shower the valve turns on by it's self
Discussion in 'Shower & Bathtub Forum & Blog' started by ghostvalve, Oct 31, 2006.
  1. ghostvalve
    ghostvalve New Member
    Oct 31, 2006
    I have a single lever control valve that controls both temp and flow in a shower at my home. Directly after taking a shower the valve will turn on again. If I run cold water though the valve it will stay off. What is the cause of my problem?
  2. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I don't know. What make faucet is it..........
  4. Cass
    Cass Plumber
    Nov 12, 2005
    It must be ghooooooooooosts if it's happening today. :)
  5. jadnashua
    Somebody else had that problem recently, so try a search (blue bar above). If I remember, the manufacturer suggested removing some of the grease in the cartridge. What brand is it, and how old is it? Do you have a clue what your water pressure is? You can buy an inexpensive gauge from a big box store for less than $10 and screw it onto the hose valve or the washing machine supply and check it out.
  6. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Did you just do some work on that valve? I had that happen to me with a moen cartridge that I had replaced. There was a bit of the old rubber seal left in the pipe and it prevented the cartridge from being pushed in all the way. The water pressure then would slowly push the cartridge out to the "on" position.
    In any case, you need to take the cartridge out and check for gunk, too much grease, or the aforementioned old rubber seal.
Similar Threads: shower valve
Shower & Bathtub Forum & Blog Old delta shower valve not working Yesterday at 6:30 AM
Shower & Bathtub Forum & Blog ProPEX for Shower Valve & Spout Jan 31, 2017
Shower & Bathtub Forum & Blog How to remove broken nipple from shower valve stem Jan 30, 2017
Shower & Bathtub Forum & Blog Is it possible to adjust this particular shower mixing valve? Jan 19, 2017
Shower & Bathtub Forum & Blog Shower mixing valve Jan 19, 2017
