shower temp mixing valve question
Discussion in 'Shower & Bathtub Forum & Blog' started by novasupra, Apr 5, 2011.
  1. novasupra
    novasupra New Member
    Apr 5, 2011
    VA
    Hi, I have a Grohe shower set, has a rain shower head and also body spray. There is a control for the shower head and also a control for the body spray and a also a seperate control for the temperature.
    For some reason, the temperature valve does not "mix" the hot and cold water, I either get all hot or all cold but nothing in between. If I take the cover off and adjust the temperature setting, i can turn it to the point where it gets hot then if I back it off, it doesn't temper down it just stays hot and then all of a sudden it will go cold.
    Is there any other adjustment that I need to make?
    Appreciate the help.
  2. Cookie
    Cookie .
    Oct 7, 2005
    Take the cover plates off the valve take a picture of it and post it. Someone might be able to help you then.
  4. hj
    Your core must be sticking or has failed.
Similar Threads: shower temp
Shower & Bathtub Forum & Blog shower temperature fluctuation Dec 7, 2016
Shower & Bathtub Forum & Blog Shower leak from temperature control Nov 4, 2016
Shower & Bathtub Forum & Blog Replacing the temperature knob on a shower panel? Jun 28, 2016
Shower & Bathtub Forum & Blog Installing Kohler Rite-Temp Bath & Shower Valve K304 + Mastershower 2 or 3-way Transfer Valve K728 Jun 5, 2016
Shower & Bathtub Forum & Blog Shower remodel layout. Two Moen Positemp Valves Jun 5, 2016
