Shower stall problem
Discussion in 'Shower & Bathtub Forum & Blog' started by JockM, Jan 18, 2005.
  1. JockM
    JockM New Member
    Jan 18, 2005
    Snoqualmie WA
    I have a 3x4 foot shower stall in an old cabin that was installed about 4 years ago. There is a leak just behind the shower head (when the valve is turned on, water sprays out from that area as well as coming out the showerhead). What is the likely cause? A soldered connection or a threaded connection? Also, do I have to destroy the stall to get at the problem? The hole for the shower head "neck" is too small to see through, let alone fix anything through.
    Any advice will be appreciated.
    Jock :confused:
  2. Plumber2000
    Plumber2000 Plumber
    Jan 13, 2005
    Eugene, Oregon
    Well first remove the shower arm that the head connects to apply new teflon tape and reinstall the arm, tighten and test, this maybe all that is needed.
  4. JockM
    JockM New Member
    Jan 18, 2005
    Snoqualmie WA
    Thanks, I'll try that. However, I believe the arm connects behind the stall wall. I guess I'll have to cut a large hole in the stall around where the head connects. Can I get a large flange to cover the hole afterwards?
    The cabin is a ways away from my home. I won't be tthere til Spring.
  5. jimbo
    jimbo Plumber
    San Diego, CA
    The arm unscrews and screws back in with no clearance required. However, if the hole in the wall is just the size of the pipe, it may be difficult to see in with a flashligt to verify that the leak is fixed. A standard escutcheon flange is about 3" in diameter, so there is room for the hole to be enlarge a little.
Similar Threads: Shower stall
Shower & Bathtub Forum & Blog Demo'd Fiberglass Shower & Installing New Tile Shower But I Have Questions??? Saturday at 2:13 PM
Shower & Bathtub Forum & Blog Delta rain can shower head install Feb 19, 2017
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog Huge Hole in Shower stall How to Repair without purchasing new stall Dec 3, 2016
Shower & Bathtub Forum & Blog DO I NEED TO INSTALL SHOWER PAN FOR A SHOWER ON A CONCRETE FLOOR? Nov 30, 2016
