shower stall faucet and door requirements
Discussion in 'Shower & Bathtub Forum & Blog' started by n2learning, Jul 3, 2010.
  1. n2learning
    n2learning New Member
    Mar 30, 2009
    Missouri
    Building a basement bathroom that will include a 36" x 36" stand up shower.
    Can the shower faucet face the door of the shower entry?
    I read somewhere that this is NOT allowed. I wanted to get confirmation before I proceed with my design options.
    The door entry will probably just be a simple curtain rod, not a glass door.
    Thanks,
    DK
  2. jadnashua
    There are requirements on total size, and minimum door width, but I don't think there are restrictions on where the showerhead or valve are. There are convenience issues, but I don't think there are code ones.
  4. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    You can have the valve anywhere you want, but the shower head can not face out the entrance way.
  5. jimbo
    jimbo Plumber
    I do not find anything in the plumbing code, maybe it is there. It might be a building code; mainly it is just not a great idea because the shower doors are typically not designed to handle continuos direct water flow.
  6. Terry
    Aug 17, 2004
    Having the shower head face the opening is the worst idea I've seen in practice.
    1) Water will be all over the floor
    2) When ever you turn the shower on, you won't be able to duck the cold water that comes out first.
    3) When you get tired of the above two items, you will find out that they don't really make fittings to move the shower head, though you could use a hand shower and hose.
    I've only seen it done a few times, and that's normally when called out to change it.
    A curtain rod with curtain isn't going to help much.
  7. n2learning
    Mar 30, 2009
    Missouri
    Thanks for the replies, especially Terry's point 1 and 2.
  8. hj
    As to point #2, in a 36" shower you won't be able to avoid the cold water unless you turn the faucet on before you enter it, and THAT is when you will discover that the shower head spraying against the shower curtain, or even a swinging door, was a TERRIBLE idea.
  9. Denzel Parker
    Denzel Parker New Member
    Jul 6, 2010
    San diego
  10. trinitony
    trinitony New Member
    Jul 19, 2010
    md
    Thank you - was about to ask the same question.
Similar Threads: shower stall
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog Huge Hole in Shower stall How to Repair without purchasing new stall Dec 3, 2016
Shower & Bathtub Forum & Blog DO I NEED TO INSTALL SHOWER PAN FOR A SHOWER ON A CONCRETE FLOOR? Nov 30, 2016
Shower & Bathtub Forum & Blog Steam Shower Generator Installation Nov 22, 2016
