Shower Spa water flow problem
Discussion in 'Shower & Bathtub Forum & Blog' started by romy, Jul 22, 2011.
  1. romy
    romy New Member
    Jul 22, 2011
    Kingston, ON
    We have a Shower Spa with 5 jets, a Rain shower head and a handheld shower and a small spout. There are 4 control valves, so one for each feature.
    We have issues with the water flow.
    When we first turn on the spout (located closest to floor), there is relatively good waterflow for about 2 seconds, then it changes to a trickle.
    The body jets and the rain shower head have no flow at all, the handheld only gives a few drops of water.
    We build a new house and all other faucettes in the house work fine.
    We bought this unit from Costco and have no idea about the brandname.
    What do you suggest we can do?
    Has anyone heard of similiar problems?
    Thanks Romy
  2. hj
    The most common cause would be a loss of pressure in either the hot or cold lines, but we cannot tell what could cause it. A stuck balancing spool would stop either the hot OR cold, but not both.
  4. jadnashua
    There could be something caught in the valve(s) that floats to block flow once you open it. It could be a glob of solder, dirt, a pebble, a flap of teflon tape, packing material, etc.
Similar Threads: Shower water
Shower & Bathtub Forum & Blog Symmons / Temptrol valve, Water comes out of tub spigot when shower is on - New diverter did not fix Feb 27, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Water runs from handheld and wall shower same time Oct 23, 2016
