Shower Riser Height for Handheld Shower
Discussion in 'Shower & Bathtub Forum & Blog' started by terogers, Jul 8, 2014.
  1. terogers
    terogers New Member
    Jul 8, 2014
    I am installing a new Moentrol Valve that will supply a new tub spout and handheld shower (in lieu of a traditional shower head). The idea is that the handheld shower will attach to a wall bar that will have the ability to hold the handheld at a traditional height ~79". However, it will mostly be used to bathe my two daughters under 3yrs. I would like to set the nipple that the hand held attaches to at about 12" above the valve which would be about 12" above the tub spout/diverter. I stumbled across some forums that state that there is a minimum shower riser height to prevent flow from both the shower head and tub. I currently have the tub area down to the studs. Any advice is truly appreciated... Thanks!
  2. Terry
    Aug 17, 2004
    [​IMG]
    Moen instructions mention 11" as the limit for the tub spout center to center, but not really a mention for the shower. If you have a handheld with five foot hose, that's quit a bit of restriction there. I don't see an issue with that.
    The tub spout should be run in copper. :)
    No PEX or CPVC :(
  4. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Most handheld hoses have a natural bend or arc when then hang of 8"-10". Often the support of the handheld to the bar is offset 2"-4". Getting the measurements just right is easier with the hose onsite.
    Let it swing a bit in the closet for a day or two. Then hold it up with the bend to see how it looks.
    Check out this idea book of mine for more ideas.
    "How to Place Shower Controls for Bathing Bliss"
Similar Threads: Shower Riser
Shower & Bathtub Forum & Blog Riser out of plumb in two directions for new shower drain Feb 17, 2016
Shower & Bathtub Forum & Blog Riser load capacity calculation for a new shower Dec 15, 2015
Shower & Bathtub Forum & Blog Shower head riser question Nov 13, 2015
Shower & Bathtub Forum & Blog Shower trap riser tilted due to 1/4" per foot drain slope Dec 6, 2013
Shower & Bathtub Forum & Blog Help - need to shorten chrome shower riser pipe Aug 8, 2009
