shower remodel - old shower supply is PVC/replace with CPVC
Discussion in 'Shower & Bathtub Forum & Blog' started by carrotguy, Sep 23, 2008.
  1. carrotguy
    carrotguy New Member
    Mar 26, 2007
    Texas
    Hello all,
    I did a search earlier today and I think I checked all of the related threads, but I'm throwing this out here to be sure.
    I'm finishing up a shower remodel and I found that the current shower supply line is PVC, not CPVC. This is an older 3-handle price pfister manifold (where the hot, cold, and diverter valves screw in)...
    As an aside, this is a 2-bath house and the other shower supply line is apparently the original copper, but the one we're fixing now is PVC.
    There's a small leak at the manifold where the shower supply line connects. My goal is to remove the worn PVC line and install a new CPVC fitting and supply line.
    The original PVC was 1/2". I've already purchased 3/4" CPVC. The only thing I need to do now is buy the adapter that will connect the CPVC into the manifold.
    I've read that CPVC is more flexible... this is around a 5'-7' run of supply line I would guess. Is there anything that I might need to connect a CPVC shower supply line to the existing price pfister manifold other than one of those copper-to-CPVC adapters? I read something about specialty copper fittings required to go from different pipe diameters and I want to be sure I don't miss the chance to do the right thing.
  2. hj
    Cpvc
    This is an inside the wall connection and you are going to jury rig a line between the copper and the valve, and also "flex" it?
  4. carrotguy
    Mar 26, 2007
    Texas
    basically, i have to fix a shower supply line from a price pfister 3-handle manifold. the previous shower supply line was 1/2" PVC, and i wanted to replace it with 3/4" CPVC.
    i read a blurb about different expansion rates between copper and CPVC, and i thought that i would need a copper -> CPVC transition piece but i couldn't find what i needed at the orange box store last night.
    the problem i noticed last night is - when using CPVC, i couldn't find a 90 degree elbow that was threaded to accept the shower arm.
    i might have to use PVC. i know it doesn't handle hot water as well but the previous PVC supply line was in good enough shape.
  5. carrotguy
    Mar 26, 2007
    Texas
    to clarify though... i only mentioned flex as i read that CPVC needs a bit more support... there were three pipe fasteners there already but i figure with a ~5' run, those should suffice. it's going to be a straight run.
  6. psolutions
    psolutions New Member
    Sep 30, 2008
    South Carolina
    Plumbing Shower
    Are you talking about a cpvc shower ell that the shower arm screws into? Its a shower ell that screws to the backing board. You should be able to find this in cpvc and a cpvc/brass. I would get the cpvc/brass for stability.
    OR
    are you talking about the actual fittings to thread onto the valve in a 90 slip on one end and threaded on the other?
  7. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Personally I don't use CPVC But if I was threading stuff into and onto CPVC I would use fittings like this...
    [​IMG]
    [​IMG]
  8. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    I think you are spot on redwood. You are a walking supply store:D
  9. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Sounds like a repipe is in order, too.
    If the potable water in the house is PVC then it might be in your best interest to look into a whole repipe of your house. I get shivers just thinking of those PVC pipes in your walls.
  10. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I just completed installation of a new tub/shower valve. The tub and shower were piped with CPVC using the connectors as Redwood pictured. They had preformed well for over 20 years, however I replaced everything with copper. I don't trust plastic pipe.
Similar Threads: shower remodel
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
Shower & Bathtub Forum & Blog Remodeling Shower - Need help with shower drain Dec 2, 2016
Shower & Bathtub Forum & Blog Remodel shower stall kits prone to leaking? Nov 8, 2016
Shower & Bathtub Forum & Blog Shower remodel layout. Two Moen Positemp Valves Jun 5, 2016
Shower & Bathtub Forum & Blog Shower remodel plumbing dilemma Dec 8, 2015
