Shower Pressure Issue/PLEASE HELP
Discussion in 'Shower & Bathtub Forum & Blog' started by mrshikadance2000, Dec 10, 2007.
  1. mrshikadance2000
    mrshikadance2000 New Member
    Dec 10, 2007
    Hello,
    I recently had my bathrooms remodeled and also did copper repiping. I have back to back bathrooms (one bathroom has tub/shower and other just has shower). I've noticed the tub/shower has more pressure than the shower only. Is this normal? I'm fearful that there may be a small leak which is causing less pressure for the shower only bathroom (note, pressure for the sinks in both bathrooms are the same).
    thanks for your help/advice.
  2. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Shower heads have 2.5 gal restricter as per fed regulations.Tub spouts do not.
  4. mrshikadance2000
    Dec 10, 2007
    Sorry for the ambiguity. I was comparing Showerhead to Showerheard pressure. I have installed the moen TS374 in the bathroom with tub/shower, and the TS372 (same exact model, but shower only). I've read the specs for both, and both have a 2.5 gallon restricter for showering, but the tub/shower bath delivers greater pressure than the shower only, which leads me to thinking that the shower only is delivering less than 2.5 gallons.
    http://showhouse.moen.com/catalog/selectfinish.cfm?sku=TS374&ctype=solaceshower
  5. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    There may be some gunk partially blocking the flow in the shower-only head. Take it off and check. Also, see how the pressure is without the shower head.
  6. mrshikadance2000
    Dec 10, 2007
    I checked the shower head last night. no gunk backing it up. Maybe i'll get into the crawl space and see if there is a leak.
  7. jadnashua
    Are the shower heads identical? There can be a huge difference in apparant flow and pressure between different brands and models of heads.
    If you take the heads off and let it run into a bucket for a timed interval, say 1 or two minutes, and then compare how much water comes out of the pipe you'll have an idea of the flow possibilities. But, keep in mind, on the tub/shower, they sometimes put different sized openings off of the valve. If the divertor is external to the valve, you may be taking it from the unrestricted tub side on one, and the restricted shower side on the other. That would affect the flow, but the total pressure should remain the same as the size of the opening should be more than sufficient for the 2.5gpm head.
  8. Verdeboy
    Jun 12, 2006
    If you're satisfied that there is no leak, you can try to find a higher-flow shower head. Some shower heads actually have a washer that can be removed to increase the flow.
  9. mrshikadance2000
    Dec 10, 2007
    Yes,
    The shower heads are identical. This is a stupid question, but is going into the crawl space with a flashlight while the water is running the easiest way to tell if there is a leak?
    thanks!
  10. Verdeboy
    Jun 12, 2006
    Whatever it takes to make a visual inspection of the pipes is the best way. But if the ground is not wet in the crawl space, chances are there is no leak.
Similar Threads: Shower Pressure
Shower & Bathtub Forum & Blog Shower Pressure Problem Jan 21, 2017
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Best type of shower mixing valve / highrise bldg with poor pressure balance Dec 21, 2016
Shower & Bathtub Forum & Blog Concern of water pressure on well for dual shower head setup Dec 5, 2015
Shower & Bathtub Forum & Blog Shower pressure Oct 26, 2015
