shower pan
Discussion in 'Shower & Bathtub Forum & Blog' started by drjch, Jun 14, 2007.
  1. drjch
    drjch New Member
    Jun 14, 2007
    I recently purchased a house built in 1935 that had very little maintaining. I had to tear out the downstairs bathroom to repair the support joist that had rotted out because of the shower leaks. I have brought 2 tile guys in to build a shower pan and retile but both tell me it can't be done. Heres the problem. It is an old plaster walled house that does not have studs on the outside walls. Therefore they tell me they cant install the liner membrane as they have no studs to attach it to. I have looked all over the internet for a fiberglass pan but nothing comes close to my size, 51 X 36. Is there a way to build a shower pan by maybe gluing the liner to the 2 outside walls? I need help. Thanks for those that reply.
    JCH
  2. jimbo
    jimbo Plumber
    What are the walls made of? You could always furr out the wall with some 2X or 1X. I have to believe there is a way to do this. Some pictures will help. And your best resource for this particular project is our friends at this tile forum: www.johnbridgel.com
  4. drjch
    drjch New Member
    Jun 14, 2007
    Thanks for your reply. This outer walls of this house was built with those old fire brick looking blocks. The regular bricks are cemented to these blocks on the outside. On the inside it looks like it was a plaster type/cement with the wire mesh in it that was applied directly to the fire brick. then the tile was glued on top of that. When I took out the shower, it was constructed of cement, but had no liner. The reason that I cant use a 60 X 36 is that my walls can't be altered because two of the walls are exterior walls. I thought about using ultraset and making my own linger then doing the bed on top of that but I just don't know if that will last.
  5. jadnashua
    You might be able to use the existing exterior walls as a base (although, with no insulation, YOu might want to consider a wall) and use Kerdi directly on it from www.schluter.com or you could put up Wedi board (which is a foam board with a special concrete on each side) which would add insulation and be able to be glued to the existing walls. Both of these are waterproof and tiled. Wedi has preformed pans that are modular and can be cut to size (within reason) that are tileable. Kerdi's preformed pans are also trimmable, but aren't as flexible...but, you can use membrane over a single custom sloped mudbed. Either of these methods can make a totally waterproof shower. Wedi and Kerdi are both European systems, accepted by US codes (at least the national ones), and have been around for quite awhile. Wedi isn't as well established in the US. They have a US website, but I usually look starting from this one www.wedi.de. If you can't find the stuff locally, both of them can be purchased and shippped...the components are light.
Similar Threads: shower
Shower & Bathtub Forum & Blog Shower drain size going from tub to shower Saturday at 4:17 PM
Shower & Bathtub Forum & Blog Old delta shower valve not working Saturday at 6:30 AM
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Feb 20, 2017
Shower & Bathtub Forum & Blog Delta rain can shower head install Feb 19, 2017
Shower & Bathtub Forum & Blog Cutting into block wall for shower water supply Feb 14, 2017
