Shower Pan Install
Discussion in 'Shower & Bathtub Forum & Blog' started by Walter Schwartz, Feb 26, 2014.
  1. Walter Schwartz
    Walter Schwartz New Member
    Oct 30, 2007
    Illinois
    I plan to install a new bathroom with shower in my basement. If my fairly new concrete floor is level in that area, is it necessary to use thin set underneath the shower pan. Is there something else to put under the pan, or is the pan ok by itself?
  2. jadnashua
    What kind of pan? It makes a big difference, depending. Also, what does the manufacturer's instructions say? In most cases, it helps, and in some cases, if you don't do more than just thinset, the pan will fail prematurely. So, there is no one right answer...need more info.
  4. Walter Schwartz
    Oct 30, 2007
    Illinois
    I haven't purchased the shower pan yet. I was just looking into it to see what is necessary to install it. I saw online where someone was installing a shower pan and they just put this felt pad underneath it. May not have been on a concrete floor though. What would fail with a pan if just using thinset?
  5. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Many of us prefer to use a few piles of mortar "mushed" into place when setting a fiberglass or acrylic pan. This makes the pan feel very solid and eliminates any flex that might otherwise lead to a leaky drain or a cracked pan.
  6. jadnashua
    The big thing, is, you do not want the pan to rock AND you want the bottom of it fully supported so it doesn't flex. Now, some are quite sturdy, and if the floor IS flat, you may not need to do anything, but there is no one right answer without having the thing first and then, seeing how well it actually sits on YOUR floor. Flex, over time, can cause stress cracks.
    Now, if you're going to tile the walls, you might want to consider tiling the pan as well. How you do that depends on the system you use. You might want to check out www.johnbridge.com for tiling help and some other opinions.
Similar Threads: Shower Install
Shower & Bathtub Forum & Blog Delta rain can shower head install Feb 19, 2017
Shower & Bathtub Forum & Blog Shower installation over a sump pit in a concrete floor with radiant heat Jan 1, 2017
Shower & Bathtub Forum & Blog DO I NEED TO INSTALL SHOWER PAN FOR A SHOWER ON A CONCRETE FLOOR? Nov 30, 2016
Shower & Bathtub Forum & Blog Steam Shower Generator Installation Nov 22, 2016
Shower & Bathtub Forum & Blog Shower base install - cbu before or after? Nov 18, 2016
