Shower pan drain removal help
Discussion in 'Shower & Bathtub Forum & Blog' started by cydown, May 26, 2010.
  1. cydown
    cydown New Member
    Sep 21, 2009
    CT
    Hello,
    I am in the process of replacing a 2nd Floor Shower pan and am at the step of separating the pan and gasket from the drain pipe. I don't see a rubber gasket to remove as expected and it appears to be an older style (possible lead oakum filled?). Is there a way I can remove it without damaging the pipe? I would like to avoid opening up the ceiling below if possible. The new shower pan I have came with the gasket and indicates that I do not need to have access to the floor below to install it.
    Thanks
    cydown
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
    That is a lead and oakum joint. Drill a few holes through the lead and pick the remaining lead out to remove the base. Depending on the size of the base they can be very heavy. They can be broken into peaces with a large hammer if need be.
    John
  4. cydown
    cydown New Member
    Sep 21, 2009
    CT
    Thanks John. I will give that a shot. Thanks for the heads up on the base weight.
  5. hj
    Also, depending on the pipe's material, you need the correct gasket for the new drain, or it will NOT seal properly.
  6. shacko
    shacko Master Plumber-Gas Fitter
    Jan 22, 2006
    Rosedale, Md
    You do realize that if the new shower pan is not the same size and shape the drain will have to be changed.
Similar Threads: Shower drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
