Shower noise
Discussion in 'Shower & Bathtub Forum & Blog' started by nadia, Sep 26, 2012.
  1. nadia
    nadia New Member
    Sep 26, 2012
    Texas
    I have a moen single shower faucet and it makes a noise when the water handle is in the middle the noise stops when the handle is all the way on hot or cold. Do you know what the problem is
  2. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    I wish I could help you. Sometimes showers make strange noises. Is it a new install or and older one?
    JW
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    You have not provided enough information to determine whether the "problem" is real or imagined. Is this a new installation or old? If old, has the noise level changed over time?
    Most modern shower valves have a pressure balance spool that monitors the pressure on both supplies and meters the output accordingly. This spool can produce a sound. The constriction of flow through the valve also produces a sound. When the control is set to full hot or full cold, the restriction on one side is less and the pressure balance spool seeing only one side has no role to play.
  5. hj
    In the ''middle" is when the flow is the greatest. Take the shower head off and run the water to see if that is where the noise is occurring.
  6. Natineah
    Natineah New Member
    Sep 28, 2012
    I suggest that you call a plumber in your area because I can't really determine the problem of your shower.
  7. nadia
    nadia New Member
    Sep 26, 2012
    Texas
  8. nadia
    nadia New Member
    Sep 26, 2012
    Texas
    It is an older shower.It is a townhouse built in 2007 and I just bought it and the sound is very loud.When the water is on it does not make a noise when the handle is all the way on hot or cold but when the handle is in the middle after a few minutes the sound starts. I have taken the shower head down but the noise still comes through the water pipe.
  9. nadia
    nadia New Member
    Sep 26, 2012
    Texas
    I took the shower head down and the noise was still coming through the pipe.
Similar Threads: Shower noise
Shower & Bathtub Forum & Blog Shower pressure dropped and noise increased Jun 7, 2014
Shower & Bathtub Forum & Blog HELP....Shower valves/Pressure relief valves make noise - no one has an answer...yet Dec 19, 2013
Shower & Bathtub Forum & Blog shower pan making popping noise after shower Apr 13, 2007
Shower & Bathtub Forum & Blog shower body machine gun noise Mar 19, 2007
Shower & Bathtub Forum & Blog clunking noise from shower faucet Dec 13, 2006
