Shower Mixing Valve or Tank not putting hot water through
kwspears
Chesapeake, Virginia
I have a shower that can't get beyond luke warm. Sink next to it gets plenty of hot water. I have sterling fixtures throughout and the house is about 15 years old. I changed out the mixing valve, but that didn't completely solve the problem. I can finally get medium warm water if I let it run for 5 minutes, and then, every once in a while full hot water comes through (not good if you're in the shower!). Attaching 2 pictures. Do I need to replace the mixing tank/fixture behind the valve, clean something out somehow, or something else? Trying to avoid the major plumbing bill if I can.... IMG_1382 (598x800).jpgIMG_1377 (598x800).jpg
Do you have a hot water circulation system and pump? That valve does not appear to have a "temperature limiting stop", so if everything else is proper, you should get maximum hot water when it is turned all the way to the left. BUT, a malfunctioning circulation system CAN produce your symptoms.
Jimbo
San Diego, CA
The piece with the word "up" on it is the balancing spool. Pull it out with needle nose pliers, and replace it.
kwspears
Thanks for the information on the balancing spool! Will give that a try. Is it there any trick to pulling it out? (Trying to avoid a Tim the Toolman moment!).
