Shower leaking
Discussion in 'Shower & Bathtub Forum & Blog' started by userjh160, Jan 20, 2006.
  1. userjh160
    userjh160 New Member
    Jan 20, 2006
    We purchased an old house that has what appears to be a custom shower stall, no tub. There are 2 knobs (1 hot, 1 cold) and a shower head protruding from the wall -- no name brands on anything. The problem, if we just turn the knobs off manually - the showerhead still flows water, we have to use a wrench to turn the knobs further to get the showerhead to stop flowing water after we shower. Is there anything we can do to repair?
  2. jadnashua
    The valve body can usually be replaced. You might also need to replace the valve seat (if it is a replacable type). A picture would help. Normally, if you take the handle off (usually a screw behind a decorative cap you pry off the front) you can then remove the decorative trim and then take the valve out. Take it to a good plumbing supply house, and they can usually match it up with a viable replacement. The big box stores carry the more common ones, but sometimes the generic replacements aren't the best quality.
Similar Threads: Shower leaking
Shower & Bathtub Forum & Blog New tub & shower enclosure - leaking on floor - shower curtain Jan 22, 2017
Shower & Bathtub Forum & Blog Remodel shower stall kits prone to leaking? Nov 8, 2016
Shower & Bathtub Forum & Blog New home - leaking shower arm inside wall Oct 26, 2016
Shower & Bathtub Forum & Blog Shower drain leaking Aug 13, 2016
Shower & Bathtub Forum & Blog Leaking shower drain: help replacing from top Jul 1, 2016
