Shower leaking behind faucet/wall
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Anton Derson, Feb 15, 2013.
  1. Anton Derson
    Anton Derson New Member
    Feb 15, 2013
    Colorado
    Ive been trying to manage this leak with my lack of plumbing knowledge. And I dont think its from the diverter. I've taken off the valve covers and removed/examined and tightened the escutcheon. I've taken pictures of my shower, and the leaky spots. I've tinkered with the water pressure with no luck.
    The leak only occurs when the shower is actuated. Both hot and cold sides leak.
    My shower setup: valve stems w/ diverter in spout to push water up shower arm:
    [​IMG]
    (yes, the cold valve screw is not in place, picture taken during my trouble-shooting)
    The leak, behind the faucet assembly
    [​IMG]
    Notice the stripped paint and water stain running down wall
    Unnecessary:
    The nuts w/ blue hold the faucet assembly to the wall, it appears.
    Edit: upon further tinkering i noticed the washered nuts w/ blue mineral deposits are loose, started to tighten but space restrictions are hindering me. To get behind the wall I must lean over very far over access wall, so far that my feet are hanging and I'm upside-down. My shoulders barley fit into the access hole, maybe just bigger than a 2'x3' hole.
Similar Threads: Shower leaking
Plumbing Forum, Professional & DIY Advice water leaking shower room condominium Jan 22, 2017
Plumbing Forum, Professional & DIY Advice Leaking tub/shower. Please Help With Your Expertise!! Nov 28, 2016
Plumbing Forum, Professional & DIY Advice Help!! Leaking shower Apr 18, 2015
Plumbing Forum, Professional & DIY Advice Solvent welded shower drain is leaking Mar 20, 2015
Plumbing Forum, Professional & DIY Advice Shower leaking?? Mar 1, 2015
