Shower is freezing, how to I adjust the temp valve?
Discussion in 'Shower & Bathtub Forum & Blog' started by jayson, Nov 16, 2009.
  1. jayson
    jayson New Member
    Nov 8, 2009
    New Jersey
    Just moved into a new house, and no matter what I do the shower is lukewarm at best! At first I thought it may be the water heater, but water comes out very hot from the tub (adjacent to the shower). This lead me to finding the temperature control valve, but I have no idea what the heck to do with this. Any advice please? (See attached image)
  2. jayson
    jayson New Member
    Nov 8, 2009
    New Jersey
    Forgot to mention, I believe it is a Moen faucet.
  4. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    you have 2 stops on that valve one on the right and one on the left. use a screw driver and make sure the left one assuming its not backwards is open all the way.
  5. jayson
    jayson New Member
    Nov 8, 2009
    New Jersey
    So - turn the left one fully counter clockwise?
  6. jayson
    jayson New Member
    Nov 8, 2009
    New Jersey
    okay, tried it out & those things seem to just turn the water from that valve on or off.
    (|) is off
    (-) is on
    Both were already set at the "full on" position.
  7. Basement_Lurker
    Basement_Lurker One who lurks
    Jun 21, 2007
    I smash things and demand money.
    Victoria, BC
    Yes, you are correct, those are just shutoffs. Sometimes they are not opened fully by the installer, which is why you were told to make sure they are open fully.
    There is no high limit on that valve. Your cartridge is probably in need of replacement.
  8. jayson
    jayson New Member
    Nov 8, 2009
    New Jersey
    So they will just spin around indefinitly, correct?
    What is the cartridge and how is it replaced? Sorry for my newbie-ness. :)
  9. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    If you put the handle on without the rest of the trim and turn it can you get hot water? also you can turn off both valves and pull the clip on the top that holds the cartridge in and then remove the cartridge and open the hot side and see if you have pressure there the close and do the same on the cold and compare. If they are the same pressure then replace the cartridge.
Similar Threads: Shower freezing
Shower & Bathtub Forum & Blog Shipping Shower Waterproofing in cold weather: How to protect from freezing Oct 17, 2014
Shower & Bathtub Forum & Blog shower drain size 18 minutes ago
Shower & Bathtub Forum & Blog Old delta shower valve not working Today at 6:30 AM
Shower & Bathtub Forum & Blog Lustrolite shower wall covering Monday at 11:17 AM
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
