Shower: insert or tile?
Discussion in 'Shower & Bathtub Forum & Blog' started by Bosun, Oct 27, 2007.
  1. Bosun
    Bosun New Member
    Jan 25, 2005
    Teacher
    Minneapolis
    I realize that the tile has the look and feel of money, but if you were showering 1-2 times a day, which one would you choose for ease of care and feeding?
  2. hj
    shower
    Can you get a one piece shower into the room? If so, that would be the least expensive option.
  4. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    And be easier to care for in the long run. No caulk or grout to get nasty in years down the road.
  5. Angelglez
    Angelglez New Member
    Oct 27, 2007
    Landlord/ Several Bldgs
    NY
    Even if you have to put it in in several pieces (base, two side...), from a maintenance point, it's easier to put a few beads of caulk than maintaining grouted walls. However, prep the walls in a water tight manner! The oldest one I have in use is 15 years old and it still looks and works great(3 piece unit).Good luck!
  6. Terry
    Aug 17, 2004
    For retrofit,
    I like using cultured marble.
    http://www.veronashowers.com/master-bath-pictures
    After removing the existing shower or tub, and removing the wall board, it's easy to drop in a new tub or shower pan,
    Install new backer board,
    And then glue the marble panels up, using Silicone at the joints.
    The panels can be poured to cover the hole left in the room by the removal of the drywall.
  7. Bosun
    Bosun New Member
    Jan 25, 2005
    Teacher
    Minneapolis
    Where?
    Where does one get cultured marble? How does it compare in cost?
    I have a 60" shower--thinking of going with Sterling.
  8. Terry
    Aug 17, 2004
    How much does cultured marble cost?
    More than a Sterling kit,
    But when you add the cost of drywall, taping, texture and painting to the cost of the Sterling, it's about even.
    One looks amazing, the other one looks more like a retrofit remodel.
    www.designersmarble.com
Similar Threads: Shower insert
Shower & Bathtub Forum & Blog Leave old tile that's straight on concrete backerboard or insert shower walls? Jan 22, 2015
Shower & Bathtub Forum & Blog Finishing Shower Insert Jan 12, 2012
Shower & Bathtub Forum & Blog squeaky shower insert Feb 19, 2008
Shower & Bathtub Forum & Blog How to finish the nailing flange on shower insert? Oct 24, 2007
Shower & Bathtub Forum & Blog Best finishing process for tub/shower inserts Aug 11, 2007
