Shower head arm female thread - best way to plumb
Discussion in 'Shower & Bathtub Forum & Blog' started by remodelingit, May 16, 2007.
  1. remodelingit
    remodelingit New Member
    May 21, 2005
    Texas
    I'm installing a Kohler shower valve and head assembly (from their designer line). The shower head arm has a 1/2" female thread where most shower head arms have a male thread. I'm still in the rough in stage so I have flexibility with how it gets mounted.
    Question: What fitting should I use on the 1/2" copper that supplies the shower head?
    My inclination is to use a 1/2" brass elbow that is most commonly used for standard shower head mounting and a 1/2" brass nipple. My problem with this approach is that I do not know how to mount the nipple to the elbow tight enough to keep it from leaking.
    All help will be greatly appreciated. Thanks in advance.
  2. markts30
    markts30 Commercial Plumber
    Sep 25, 2006
    Commercial Plumber
    Phoenix, AZ
    You can buy brass elbows that are SolderXMIP in hardware stores...
    Then just screw the arm directly onto it...
    For rough in, just make up a piece of copper with a cap on one end and an FIP on the other to put on the threaded 90 till you are ready for trim...
    (remember to allow sufficient clearance around the stub-out for removal of the nipple and install of the trim arm...)I find the easiest way to do that is slip a piece of foam pipe insilation over the nipple while drywalling and tiling...
    That way you end up with a nice even border on the hole...
Similar Threads: Shower head
Shower & Bathtub Forum & Blog Delta rain can shower head install Sunday at 7:12 AM
Shower & Bathtub Forum & Blog Repl shower head using fpt coupling--Plan C:can't catch a break Jan 31, 2017
Shower & Bathtub Forum & Blog help finding shower head diverter Jan 28, 2017
Shower & Bathtub Forum & Blog Trying to replace shower head without pipe! Dec 12, 2016
Shower & Bathtub Forum & Blog Leaky shower head Oct 2, 2016
