Shower head and valve location question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by gandude, Jan 29, 2007.
  1. gandude
    gandude New Member
    Dec 6, 2006
    Hello all,
    I am ready to install the shower in my new bath. My question pertains to the shower valve and head.
    Can I, would it look stupid, is it done, placing the showerhead and valve on the opposite side as the drain? The shower is 60" wide and 32" deep. Drain on left. The pan and walls are Swanstone.
    I ask because the toilet is 15" (centerline) from the shower on the side where drain is. It would be hard to access the valve from this end. The DWV was at the limit for slope, so I was unable to run the 2" to right side.
    Thanks for any help!
    Glen
  2. solsacre
    solsacre Plumber
    Nov 16, 2006
    Arkansas
    it's diffrent... but #1 will it work?
    YES
    will it look stupid????
    is this your house? are you looking for resale value or are you living there for years?
    I've installed them that way and it worked... made sense to me.
    I don't know if it'll affect the sale.
    Functional is more important than visual.... but just a little.
    Put it on the wronge side... if nobody likes it than they shouldn't be in YOUR house.
    good luck
    dances-with-pumps
    PS at a 1/4" per foot it would only be 1 1/4 inch fall to the other side
  4. hj
    valve
    As long as it is a true shower and not a shower over the bathtub, then there is no standard position for it. Some have the control where it is accessible and the head on one of the other walls or from the ceiling. Put it where it works for you.
Similar Threads: Shower head
Plumbing Forum, Professional & DIY Advice Using Rainfall Shower Head Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Moen shower head cold water only after shower remodel Jan 18, 2017
Plumbing Forum, Professional & DIY Advice For the birds: Small compact shower head for kitchen sink faucet? Aug 3, 2016
Plumbing Forum, Professional & DIY Advice Installing shower head far from valve Jun 12, 2016
Plumbing Forum, Professional & DIY Advice Should I Go Ahead And Replace Shower Valve If I'm Replacing Tile? Apr 29, 2016
